Problem with central lighting https://peugeot605.forumeurs.fr/problem-with-central-lighting-t7869.html |
Auteur: | Skojevac [ Mer 15 Juil 2020, 0:14:16 ] |
Sujet du message: | Problem with central lighting |
Hi! Its phase 1 svdt 605. I'm having strange issues with central (main) lighting. This happens when engine is turned off - when I turn on lights on button they turn off and when I turn off on button they turn on. When engine is on, I can't turn off them. Only solution is to disconnect light switch. Also, they don't react when doors are open or closed. |
Auteur: | Pepper9187 [ Mer 15 Juil 2020, 10:26:39 ] |
Sujet du message: | Re: Problem with central lighting |
Could it be a bad relay under the fusebox ? I hope not, it's a pain in the ass to remove that fusebox Do you have the peugeot servicebox installed on your computer, do you want it ? -- Edit du Mer 15 Juil 2020, 11:26:39 -- Can you access your MP or your restricted ? |
Auteur: | Skojevac [ Lun 27 Juil 2020, 17:30:02 ] |
Pepper9187 a écrit: Could it be a bad relay under the fusebox ? I hope not, it's a pain in the ass to remove that fusebox Do you have the peugeot servicebox installed on your computer, do you want it ? relais.jpg -- Edit du Mer 15 Juil 2020, 11:26:39 -- Can you access your MP or your restricted ? I have it installed, but yours seems better and no I can't access private msgs. Where should I exactly locate that relay and which color is it? Thank you for now :) -- Edit du Mon 27 Jul 2020, 18:30:02 -- Problem is solved. Relay number 3 (the first column of relays, from left to right) was rusted. Thank you so much :) |
