Nous sommes le Dim 27 Juil 2025, 8:25:41
 Sujet du message: Problem with central lighting
MessagePosté: Mer 15 Juil 2020, 0:14:16
Hi!
Its phase 1 svdt 605. I'm having strange issues with central (main) lighting. This happens when engine is turned off - when I turn on lights on button they turn off and when I turn off on button they turn on.
When engine is on, I can't turn off them. Only solution is to disconnect light switch. Also, they don't react when doors are open or closed.
 Sujet du message: Re: Problem with central lighting
MessagePosté: Mer 15 Juil 2020, 10:26:39
Could it be a bad relay under the fusebox ?
I hope not, it's a pain in the ass to remove that fusebox
Do you have the peugeot servicebox installed on your computer, do you want it ?
relais.jpg [ 148.33 Kio | Vu 1174 fois ]
-- Edit du Mer 15 Juil 2020, 11:26:39 --
Can you access your MP or your restricted ?
MessagePosté: Lun 27 Juil 2020, 17:30:02
I have it installed, but yours seems better and no I can't access private msgs. Where should I exactly locate that relay and which color is it? Thank you for now :)
-- Edit du Mon 27 Jul 2020, 18:30:02 --
Problem is solved. Relay number 3 (the first column of relays, from left to right) was rusted. Thank you so much :)
