Nous sommes le Lun 01 Déc 2025, 8:03:01
 Sujet du message: synchroniser la touche de tĂ©lĂ©commande avec la voiture?
MessagePostĂ©: Jeu 27 Juil 2017, 15:05:11
Hi friends.
I have a Peugeot 605 SLI 2.0. 1996.
The remote control to open the door doesn't work, but the key is fine.
Once a person sync up the key with the car and it worked for a while, but he didn't tell me how to sync it up.
Does someone know how to sync up the key manually with the car?
Thanks.
Salut les amis.
J'ai un Peugeot 605 SLI 2.0. 1996.
La télécommande pour ouvrir la porte ne fonctionne pas, mais la clé est bien.
Une fois qu'une personne a synchronisé la clé avec la voiture et elle a travaillé pendant un certain temps, mais il ne m'a pas dit comment la synchroniser.
Est-ce que quelqu'un sait comment synchroniser la clé manuellement avec la voiture?
Merci.
Peugeot 605
 Sujet du message: Re: synchroniser la touche de tĂ©lĂ©commande avec la voiture?
MessagePostĂ©: Mer 11 Oct 2017, 16:52:13
Il faut mettre le contact, entrer son code antidemarrate puis appuyer sur la telecommande quelques secondes.
Pour moi cela a marche a la 2em tentative, je ne suis pas certain qu'il faille le faire 2 fois (j'ai peut etre foire la premiere fois).
Hi.
You need to turn on the ignition (not necessary to turn on the engine), enter your pincode, and then press the remote control for a couple of seconds.
It worked after 2 attempts for me, not sure that you really need to do it twice or if i just screwed up the first time, just give it a try.
MessagePostĂ©: Mer 08 Nov 2017, 14:50:16
Hi.
Thanks for the answer.
I tried it several times, and didn't work at all :sad:
I did it just as you say, but waiting sometimes 2 secs, other times 15 secs, other times more.. and maybe more than 30 times (I try it every time I go to the car)
So I think it doesn't have solution :sad: I know the key is fine tho, so I think the problem comes from the car.
I have to change the ECU (Electronic Central Unit), because some fails I think comes from there.
Maybe that would solve the problem?
Thanks for the help.
Best Regards.
Merci d'avoir répondu.
Je l'ai essayé plusieurs fois et je n'ai pas travaillé du tout: triste:
Je l'ai fait comme vous le dites, mais j'attends parfois 2 secondes, d'autres fois 15 secondes, d'autres fois plus ... et peut-ĂŞtre plus de 20 fois (je l'essaie Ă  chaque fois que je vais Ă  la voiture)
Donc je pense qu'il n'y a pas de solution: triste: je sais que la clé est bien, donc je pense que le problème vient de la voiture.
Je dois changer l'ECU (Unité centrale électronique), parce que certains échoue je pense vient de là.
Peut-être que cela résoudrait le problème?
Merci pour l'aide.
Meilleures salutations.
Peugeot 605
