peugeot605.forumeurs.fr
605 en cours, demandez moi n'importe quoi
http://peugeot605.forumeurs.fr/605-cours-demandez-moi-importe-quoi-t8052.html
Page 1 sur 1
Auteur:  Skojevac [ Mer 27 Avr 2022, 15:37:46 ]
Sujet du message:  605 en cours, demandez moi n'importe quoi
Hello my fellow French people! :)
I am currently working on my 605, I am repairing everything what is broken and doesnt work. I am making this topic so you can ask me anything about things that are in your interest, about things you need to see but can't reach on your car, about dissasembling parts and all other stuffs. I will make you photos for what you need and explain you for something if neccessery. Here are the pictures of current work. Its SV trim, and 1992 year. Engine is 2.1TD older version Btw. thanks very much to Jeff for helping me to get parts from France and making it possible to repair this car :wink:
P.S. I will not work on rear side of the car.
https://ibb.co/XkYd8Dz
https://ibb.co/S3ywC0Y
https://ibb.co/tpKQgK0
https://ibb.co/z75DnSB
Auteur:  debeno [ Jeu 28 Avr 2022, 14:29:19 ]
Sujet du message:  Re: 605 en cours, demandez moi n'importe quoi
:-D Super équipement pour super projet. Je suis impatient de voir la suite ! Bravo
:smile: Great equipment for great project. I can't wait to see the sequel! Cheer
:bybye:
Auteur:  Skojevac [ Jeu 28 Avr 2022, 21:02:58 ]
:bybye:
Thanks for translate and thanks for your kind words :-D
I will eventually update this topic if no one shows up with any questions or requests. I hope I didn't miss forum category for this topic :neutral:
Auteur:  huseyin [ Lun 04 Déc 2023, 18:35:17 ]
bonjour j ai 2 605 2.5 td ,une en donneuse et l autre que j ai refait avec un ami le moteur (courroie de distribution cassé) elle avait 160 000 et maintenant 180000 et un peu plus car le compteur fonctionne de maniere aleatoir...
j ai les silent bloc moteur a changer et j en trouve pas.
la telecommande ne marche plus et c est genant par ce froid (les serrures geles)
j aurai le turbo a remplacer, et en ce moment le demarreur me lache .
si vous avez une solution a chacun de mes problemes je suis preneur
merci pour votre retour
Auteur:  cccc [ Lun 11 Déc 2023, 12:46:28 ]
c'est une 2.1 td ou 2.5 td ? ca change tout pour les pieces :shock:
Auteur:  Skojevac [ Lun 11 Déc 2023, 22:24:19 ]
Hello. I am glad you asked about your problems. I will happily try to help you. I will originaly write on English because I am not from France so I will translate it so you can compare words if something is not translated properly.
Problem 1. Can you show me how your engine mounts look like?
Problem 2. I had this same problem. For the start you can check on three things.
- maybe its stupid but check the remote battery
- your code reciever maybe died because of water or moisture. It is located behind the lamps cover on the roof. See if it is rusty. This is the part I am talking about:
https://i.ebayimg.com/images/g/2HIAAOSw ... -l1200.jpg and it is located under this plastic cover ---
https://www.usedecus.com/images/product ... 7123_n.jpg
- other solution is that maybe connector disconnected from central lock control box or it also died completely (probably it didn't). It is located under the passenger seat dashboard. It looks like this:
https://www.usedecus.com/en/peugeot/605 ... 601886380/ or it is in grey color but the same shape.
Problem 3. I don't know how can I help you with this one, you need new starter or some part of it? I doubt you don't have parts in France for that.
I hope I helped you even a bit :razz:
TRANSLATE
Bonjour. Je suis heureux que vous ayez posé des questions sur vos problèmes. Je serai heureux d'essayer de vous aider. J'écrirai à l'origine en anglais parce que je ne viens pas de France, donc je le traduirai afin que vous puissiez comparer les mots si quelque chose n'est pas traduit correctement.
Problème 1. Pouvez-vous me montrer à quoi ressemblent vos supports moteur ?
Problème 2. J'ai eu ce même problème. Pour commencer, vous pouvez vérifier trois choses.
- c'est peut-être stupide mais vérifie la batterie de la télécommande
- Votre récepteur de code est peut-être mort à cause de l'eau ou de l'humidité. Il est situé derrière le cache des lampes sur le toit. Voyez s'il est rouillé. C'est de cette partie dont je parle :
https://i.ebayimg.com/images/g/2HIAAOSw ... -l1200.jpg et il se trouve sous ce couvercle en plastique ---
- une autre solution est peut-être que le connecteur s'est déconnecté du boîtier de commande du verrouillage central ou qu'il est également complètement mort (probablement pas). Il est situé sous le tableau de bord du siège passager. Cela ressemble à ceci :
https://www.usedecus.com/en/peugeot/605 ... 601886380/ ou il est de couleur grise mais de même forme.
Problème 3. Je ne sais pas comment puis-je vous aider avec celui-ci, vous avez besoin d'un nouveau démarreur ou d'une partie de celui-ci ? Je doute que vous n'ayez pas de pièces en France pour ça.
J'espère t'avoir aidé ne serait-ce qu'un peu :razz:
