Nous sommes le Jeu 26 Juin 2025, 20:37:20
 Sujet du message: XU10 motor removal - without gearbox?
MessagePosté: Sam 28 Mar 2009, 7:56:19
Hi, I am replacing my engine (XU10J4) as after THREE days finally being road legal the cambelt snapped :???: :shock: :beua: . I will use one from a 306: either from an Xsi (8 valve, 125hp :mad: ) or GTi-6 (16 valve, 167hp :saute: ). It seems like the 605 engine may have a special sump to clear the front crossmember?
Can the XU10 be removed without removing the gearbox?! It looks as if there is just enough space to move the motor left, clearing the gearbox before raising vertically. I like the idea of NOT having to lift both and remove driveshafts etc!
Previously I have changed 405 engines, it was quite tight removing engine & box together. I ran Megasquirt on my 405 for two years (10,000km) and was a great system. I am considering using it on the 605 and fitting natural gas injectors (CNG/GNV etc ) alongside the petrol ones.
Thanks
Jason
1996 2l 605 151k, 1990 V6 505 Familiale 235k (custom), 1971 504 GL
 Sujet du message: Re: XU10 motor removal - without gearbox?
MessagePosté: Sam 28 Mar 2009, 19:28:12
pprrrrrtttttttttttt pffffffffffffffff.........................
j'ai rien compris :loll: :loll: :loll: :loll:
MessagePosté: Sam 28 Mar 2009, 20:33:31
Ah bon, et moi qui pensait que c'était du chti :mdrr: .
Jason: i'm sorry, but for this i can't help you.
MessagePosté: Sam 28 Mar 2009, 21:26:26
Dans les grandes lignes, c'est quoi son souci au juste
MessagePosté: Sam 28 Mar 2009, 21:32:43
traduit gilles :dents:
MessagePosté: Sam 28 Mar 2009, 21:33:30
J'ai tenté, mais pas trop bien cerné la chose quand même :dents:
MessagePosté: Sam 28 Mar 2009, 23:40:57
c'est le nouveau titre de mickael jackson?
MessagePosté: Dim 29 Mar 2009, 9:23:40
I can see I will have to learn French after all...or try the computer translation again:
Est-il possible d'enlever le moteur XU10 sans boîte de vitesse ? (4HP18)
Il semble qu'il peut y avoir assez de dégagement pour déplacer le moteur laissé alors vers le haut?
Je prévois d'essayer de toute façon...
MessagePosté: Lun 30 Mar 2009, 21:19:22
Je tente la traduction intégrale du texte de Jason:
Bonjour.
Je suis en train de remplacer mon moteur (XU10J4) car après TROIS jours de "finally being road legal", la courroie d'arbre à cames a cassé.
J'en ai un qui provient d'une 306 : soit une XSi 8 soupapes de 125 cv, soit une GTI 16 de 167 cv. Il ressemble au moteur de 605, peut-être avec un carter spécial pour "clear the front crossmember"?
Est-ce que le XU10 peut-être déposé sans la boite de vitesses? Il semble y avoir juste assez de place pour sortir le moteur , en écartant la boite de vitesses, avant de le sortir verticalement. J'apprécierais cette possibilité de ne pas sortir l'ensemble, les transmissions etc.
J'ai déjà remplacé des moteurs de 405, c'était facile de déposer moteur et boite ensemble. J'ai couru "Megasquirt" avec ma 405 pendant 2 ans (10 000 km) et c'était un bon système.
Je l'utilise sur ma 605 qui carbure à l'injection de gaz naturel (CNG / GNV) et aussi à l'essence.
Voila. Je ne suis pas sûr de tout bien comprendre, mais sa question est de savoir si oui ou non il est possible de sortir ce moteur (le XU10J4) seul sans déposer la boite de vitesses. Qui peut répondre?
