Nous sommes le Ven 02 Jan 2026, 8:20:51
 Sujet du message: 2.0turbo by dandzaman
MessagePostĂ©: Lun 23 Nov 2009, 23:05:50
hallo to all of you 605 enthusiast ;)
i will use english because i do not speak french :( I will try to follow this forum with a little assistance of google translator ;)
i did some modifications of my 605 so i will try to post here what i did and hope i'll get some critics from you since this is the best 605forum i found on the internet ;)
so i will post some pic's from begining ....
this is how all started...
605 2.0l petrol not in good shape...
when I bought this car i was happy because of this...:)
and then this happens..
audio system...
-- Edit du Mon 23 Nov 2009, 23:02:13 --
then i started to play because i was really bored...
and then my friend was bored :D ....
until i decided that the engine i had was weak and that i nead a little bit more power..
so my engine...
(replaced 2.0 8v with 2.0 8v turbo also stock from 605...in pretty good shape...)
(and of course in the same time a changed the complete instalation on the car..
then i got the idea(mostly because the original headlights are really expensive in Serbia )that i use lamps from 306 ...so i bought the lamps on the ebay..
and then the body...
when u mask all that with the black paint...
in the same time i did the shaved door ...
2.0turbo 180bhp
 Sujet du message: Re: 2.0turbo by dandzaman
MessagePostĂ©: Lun 23 Nov 2009, 23:08:18
:-D pour la création de ton topic, néanmoins, tu devrais mettre tes photos sur le forum, selon le procédé existant.
Je te donne le lien explicatif :
http://peugeot605.forumeurs.fr/mettre-ligne-des-photos-sur-forum-t3527.html
MessagePostĂ©: Lun 23 Nov 2009, 23:15:58
then i decide to get to work properly ...
audio system:
and of course the bass...
i was really happy with the results......
this was really hard to do it (the one who did it know's what i'm taking about....
back panel..
the dashboard was really bad so this is how i changed that..
this is how it started...
and this is how it end...
but then i played a little bit and got the steering wheel form 206.....
and that's it ...
-- Edit du Mon 23 Nov 2009, 23:13:49 --
sorry for this,
but my french is really bad so i havent see the forum rulles about that :(
i will post all pics from my pic serv and then i will change all pics if that is ok with the forum rules because there is really lott of pic's to change and i dont have time rigth now...
thanx in forward :)
-- Edit du Mon 23 Nov 2009, 23:15:57 --
then i get rid of all plastics and get my old ones.....vwith some little changes...
lower springs 40/40
Black&Diamond ....
wheels 17'' aez...
and then new paint...
night pic's...
2.0turbo 180bhp
MessagePostĂ©: Lun 23 Nov 2009, 23:18:41
Fast and furious..... :twisted:
MessagePostĂ©: Lun 23 Nov 2009, 23:38:25
HDR photo sesion...
new wheels perhaps.....
little night photo sesion...
-- Edit du Mon 23 Nov 2009, 23:38:25 --
then i got rid of my trunk and build an engine that has over 180bhp...hahaha :D
this is the car that among peugeot cars in Serbia only RC can beat me on drag race ....
with all wight that 605 got i beat 205gti,205mi16,206gti,s16,406 2.0 16v,605 v6 and 24v,306 gti6...rc beats me every time but i am not sure if he is using his NOS....he said not but...:)
so ,modifications i did...
chip the ECU,boost a turbocharger up to 1bar ,fuel pressure regulator,lose CAT ,just back exhaust with fi60 tubes...
and what i plane in the future is...
bigger turbo (kkk k26 or some similar up to 250hp),all metal tubes in the engine compartment ,other fuel pump and just a few more thing to get 250hp with stock internals...:)
if it blows up....i just buy a new one :)
2.0turbo 180bhp
MessagePostĂ©: Mar 24 Nov 2009, 7:22:31
Hello dandzaman :razz:
Lot of hours on your car and great work :-D
MessagePostĂ©: Mar 24 Nov 2009, 10:37:28
thank you very much ;)
yeah,lot of hours because i wanted to do this all by my self...i didnt knew what i was geting in to when i start all this and now i know a lot...great hoby ;)
i have a friend from Bulgaria who's making t16 from xu10j2te ...i will see to get him to show his project on this forum ...most serious project i have ever seen someone makes with 605....he dont care for nice car he just want fast car ...:)
2.0turbo 180bhp
MessagePostĂ©: Mar 24 Nov 2009, 14:43:17
Hi Dandzaman, very nice caraudio work :razz:
MessagePostĂ©: Mar 24 Nov 2009, 20:28:05
thanx for the compliments ppl ;)
I appreciate it ;)
is there someone on this forum who can get me a few things for my pug ?
i dont need big things since the shipping from France is way to expensive for me ,but climate control panel from ph2 and few more thing would not be a problem i think...
any info or link to a theme on forum would be helpfull ;)
2.0turbo 180bhp
MessagePostĂ©: Mar 24 Nov 2009, 20:49:41
Cześć dandzaman...
Nie znam po angelsku ale miślę że możeś mi rozumieć po polsku dlatego że twój język jest słowiański.
Fine twój auto i dużo pracy zrobiłeś.
Salut dandzaman
Je ne puis parler anglais mais je pense que tu pourras me comprendre etant donne que ta langue est une langue slave
Sympathique ton auto et beaucoup de travail as-tu realise.
Honda CM 125 C
MZ RT125
MessagePostĂ©: Mar 24 Nov 2009, 21:33:32
dzięki,
Rozumiem przez mało, ale musiałem użyć google tłumacz ...
że wiele pracy zostało zrobione, ale mam jeszcze czas, na jaki miałem w trakcie prac, chciałbym zrobić innego 605, ale tym razem będzie grał z 3.0 24V z dwoma turbosprężarki w silniku ....
english...
thanks,
I understand a little but I had to use google translator ...
that much work has been done, but if i had a little time now as I had during the works, I'd done another 605, but this time would be played with the 3.0 24V with two turbochargers in the engine ....
2.0turbo 180bhp
MessagePostĂ©: Mar 24 Nov 2009, 21:45:14
Już kupiłeś 605 sv 24?
As-tu deja fait l'acquisition de la 605 sv 24?
Honda CM 125 C
MZ RT125
MessagePostĂ©: Mar 24 Nov 2009, 21:59:25
i will buy it maybe next year,new model ;)
why ,do you have one to sell? :)
2.0turbo 180bhp
MessagePostĂ©: Mar 24 Nov 2009, 23:55:26
Nie!
W Francij, teraz, nie są duże 605... Ale, czy jesteś interesowany, mogę ci uprzedzić kiedy widzę jeden na okasi.
Non!
En France, maintenant, il n'y a "plus" beaucoup de 605...
( mais la, peut-etre que je me trompe, c'est juste mon impression...)Mais si tu est interesse, je peux te prevenir si j'en vois en occasion.
Honda CM 125 C
MZ RT125
MessagePostĂ©: Mer 25 Nov 2009, 9:05:52
Message Ă  Fande605 :
Tu es invité à éditer tes messages en ajoutant une traduction en Français, ce qui permettra aux membres de mieux apprécier le Serbo-Croate.
You rather ought to add a French translation to your messages written in Serbo-Croat.
MessagePostĂ©: Mer 25 Nov 2009, 23:40:11
@Alc....it is Polish ,not Serb or Croatian .... Really ? So, I apologize...
i am using trnaslator too in order to understand him :)
life is more simple when all ppl r trying more ;)
@Fande...when u find smtn interesting please let me know ;)
Edit = alc
2.0turbo 180bhp
MessagePostĂ©: Jeu 26 Nov 2009, 17:03:35
Entendu "alc", je m'execute!
Honda CM 125 C
MZ RT125
MessagePostĂ©: Lun 30 Nov 2009, 21:34:27
maybe i can get some help finding some parts for my car from the members ....
does someone knows where i can find original rubber door seels or how it should be translate :D
i have most of the used parts here but i need a new one ...
every hint can be usefull....
2.0turbo 180bhp
